Heater fan fuse
(In Topic #75595)
Heater fan fuse
Cheers,
Mike. :roll:
cheers.
If that aint it, then its shortin somwhere else. Multi-meter time!
thanks
http://cabby-info.com/Files/ReplacingTheBlowerMotor.pdf has a/c motor repair and replace with good pictures.hayhur01 said
hey satelliteone…that picces is no longer viewable …any chance you could re-post please?
thanks
I would check that your ground connection on the 5 pin molex connector is good. They have a tendency to corrode and melt, causing the fuse to pop under higher loads.
