Heater blower relay?
(In Topic #146740)
The only remaining job today is the heater blower.
I've checked the motor, and all three speeds are fine with a jumper from the battery, at the fuse box (n°10) there's no power, but again with a jumper I can power the switch, and get all three speeds, so the fault must be in the power supply to the heater blower fuse. Is there a relay for this? I've been through the diagrams, but can't identify the relay or power supply to the heater fuse.
Here's the fusebox: (LHD '79 diesel GLD with rear wiper, etc) Blower fuse in n°10, and with power supplied to it, the heater blower runs fine…
Any ideas?
VW Golf 1500D 5-door 1978 - was daily (wet)
VW Golf 1800 cabriolet 1980 - daily (dry)
Bedford CF Trailblazer 1978 - camper
Bedford CF 350 Flatbed 1976 - fun/work
Mercedes W108 280s 1970 - dusty and forgotten
Mercedes S123 200T 1983 - to be renovated
Mercedes C124 1989 - Winter Beater
BMW E21 1976/82 - dusty but not forgotten
Twingo 2004 (not my fault, somebody gave it to me!)
since everything else is working and the wiring is untouched, I'll rig up an extra lead from the relay to the fuse, then.
Robin
I put a shunter wire in to power the heater blower to go for the MOT today, then removed the wire to solder terminals on, and the heater continued running… It clearly just needed a boost to clear the dust off the terminals.
Thanks again!
Robin
