headlight problems
(In Topic #111700)
headlight problems
got some headlight probs on my 81 cabby. i get sidelights no low beam but i do get high beam. ive got a new switch on the way but i not sure if it could be a relay as well?
any help
also if anyone has an electronic version of an 81 cabby's wiring would be grateful if you could email me a copy
any help
<a><img></a>
anyone any ideas?
<a><img></a>
Could be the switch on the stalks, the main light switch controls the main & dipped as part of the same circuit which is then controlled by the stalk switch, so unlikely that the main switch would be the cause of this problem. As far as I can remember there is no relay on the main & dipped circuit.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
check the fuses, different one on each side. also its possible the dim dip filament has blown in both bulbs
just had the same problem but i had not wipers either!!! got a auto electrican out!! he said it the switch and also the ignition electrics so i have changed both and now hey presto they all work like a dream!! could be the stalk like they say!!! i have a spare if u want to try it or where about are u could pop around and take a look at mine to see if my parts work on urs!!
take it easy carl
take it easy carl
fitted the new switch and it still doesn't work. im not getting live to the low beam section of the bulb.
so i could be the stalks?
i live near bar hill in cambridge at the start A14 if you can help that would be great. or is it to far
<a><img></a>
could be the stalks aye, since all voltage for dipped/main pass thru em. i take it the fuses are deffo ok?
yeah all fine now. they used to blow instantly but i found the problem fo that. last owner wired the live from the low beams straight to the earth on the spots and would instantly blow. thats sorted no
so i need new stalks do i?
<a><img></a>
possibly, i assume you have the original S1 glass/ceramic fusebox in there? I'll have a dig thru the MK1 haynes later see if i can figure it
yeah i got one of them lol
that would be very nice if you could do that
if you could scan it and email it to me that would be great
<a><img></a>
think i found the problem. i was told to check the electrics to at the back of the ignition barrel and found this
the imobilises must connect to that
so i think i need to get a professional to sort it all out
unless any of you are good with electrics
<a><img></a>
yeah thats not right! If you're anywhere near Reading I could look at it. I promise I'll get round to checkign the diagrams soon
lol nowhere near reading mste. i live in cambridge lol
<a><img></a>
is it a dimdip loom on that?
pretty sure its too early for that, my 83 cab certainly doesnt have it?
no dont think so.
think ill pay someone to put it right
<a><img></a>
there u go mate!!!! easy if u know what ur looking at!!!
glad i was off some help!!
keep in touch about the roof
carl
carl
I scanned the 81 golf diagrams from the haynes, but my ftp server is down atm! its 4.63mb, if your email will take it pm me your address and I'll send it your way
just in case the email dont come thru, I finally got my ftp workin:
Google Sites: Sign-in
