Headlight Problem
(In Topic #73487)
Headlight Problem
Usual cause is a bad (as in no) earth for your brake light bulbs. If there is a way to to earth, the wiring will find the easiest way (lowest path of resistance) to it (eg via the headlight wiring to the H/L bulb filament which then goes to the required earth). Try cleaning up the earth connection in the LHS rear of the boot. The hex head screw should be "persuaded"out with copious amounts of dinitrol otherwise you'll just rip its head off and have to re-tap the the screw hole. For starters, take a fresh piece of wire from the rear light fitting to a good earth point.
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
1983 lhasa green GTI
1982 lemon yellow CL
