Hazard Switch Wiring .. Help!!!
(In Topic #123791)
Hi All,
I am a new member and would like to know if anyone has the following info please?
I had taken the dash out of my mark 1 cabriolet GTI and as i was doing it the Hazard Switch popped off and disconnected all the wires off the back at the same time oops.. anyway if anyone knows what colour wires go on what connections on the back it would help me a whole lot as i am desperate to get it on the road. i have looked in the haynes manual but it doesnt seem to be easy to trace wires
If anyone has any info please let me know.
or even if you could point me in the correct direction?
Thanks in advance
Matt
Thanks in advance
Matt
Hey, Thanks for that Lee, although my hazard switch does not have any white plastic plugs on the back, its just spade connections, does anyone have any pictures of which coloured wires go on which connections? Thanks again lee
Like I said to brad you should be able to reference that pic to the back of the switch mate. If you look at the back of the switch there is a large lone spade connector next to a hole (where the bulb goes) this is for the blue and black wire. Then once you have identified this connector you will be able to reference the rest of the switch to that pic. trust me look at the back of your switch with this pic in front of you and you will be easily able to work it out
I had my dashboard out today to solve some rattles, I put everything back in and now can't find the black/blue wire - where does this go to so I can chase it back from source please?
Thanks Guy
Thanks Guy
R32GUY
1992 Rivage in Classic Blue Pearl "B16YUG" 2.0 TFSI, 6 Speed FWD with Quaife LSD, running on Air with sorted geometry and Eibach ARB's, G60 brake setup front and rear, 4x100 17" BBS LM's, Power Steering, Opening Quarter-lights, Mk2 electric recaros and the whole car trimmed by MJ Interiors in tan and Alcantara with a brown roof.
Lee_dub said
Looks like a new loom Lee?
15 - blue/black
30 - red/white
31 - brown
L - black/white
R - black/green
49 - white
49a - black/white/green
58b - grey/blue
30 - red/white
31 - brown
L - black/white
R - black/green
49 - white
58b - grey/blue
Thanks very helpful all, managed to find it.
Now need to work out why my windows only work when the doors are open :-)
R32GUY
1 touch window system? check the ignition live feed, do your switches come on with the ignition?
Hi gents,
Save starting a new thread.
The blue/black wire picture above has also come loose from my hazard switch. However when I reconnect it all the electrics turn on, as if I had put the key in the ignition and turned the key once. Even without the blue/black wire connected the hazards work as they should?
Any ideas?
Any ideas?
hmm i would say hazard switch is duff, allowing perm live to back feed into the ignition live side. this feed is also then powering up the whole ignition live circuit
Jonny, you are a legend mate. I have googled alot recently re wiring and your name comes up time and time again.
A question if I may…
If the hazard swith is duff how come, that without the black/blue wire attached the switch works? It illuminates the hazard bulbs and the led behind the hazard symbol also lights up?
Again, thanks for all your help. Even posts you left from 2007 are helping mk1 owners to this day!
well its still duff, just in a way that it still works
the ignition live wire is only needed for the indicators to work, the perm live is there for the hazards. im thinking that inside the switch theres a short between the live and ignition live which is allowing current to backfeed down the ignition live wire and power up the fusebox ignition live rail.
This could be the case and yet switch still works perfectly fine so long as non of the other internal tracks are damaged
Amazing.
Thank you so much for the reply!
