hazard lights and indicator lights help plz
(In Topic #129979)
ok im having trouble with my indicators and hazard lights they just stay green on dash board !! the only way they will both work proper is if i set the hazard switch in the middle and my mot is coming and i no they will fail it !!
so far i have brought new hazard switch and checked fuses
i have looked throw the forum and seems to be common problem on golf clippers which is what i have please can someone make my xmas and help me solve this thanks for anyone that can help me out and merry xmas to all
If you are stumped and want to try changing the relay give me a shout; I got a load of relays off ebay so will probably have a spare indicator one you could have for a couple of quid plus postage.
sounds good
~Madferret
Mk1 1457cc 5door GX '83
I have changed the switch to no avail.
Ive also noticed if I get the rocker on the Hazard switch to stay in between on and off (in the middle), then the indicators work again as above.
Im have a new Relay to swap on order, but suspect its an earth, but not sure where to look.
Any help aprieciated
Schabzo said
Im sorted… It was the black/blue wire…
which black n blue wire ?
www.archwayvaleting.co.uk
thats the ignition live feed for the switch
Schabzo said
Thats the one… Its the only wire thats not part of the actual plug…
this forum is just so so dope
just saved me a whole lotta heartache and made me feel more manly too
i'm still having problems with taking out the dash, so that i can remove the lower dash, so that I can replace the carpet
but i'm also thinking of dying it, black.
