hazard lights and indicator lights help plz
(In Topic #129979)
hey guys
ok im having trouble with my indicators and hazard lights they just stay green on dash board !! the only way they will both work proper is if i set the hazard switch in the middle and my mot is coming and i no they will fail it !!
so far i have brought new hazard switch and checked fuses
i have looked throw the forum and seems to be common problem on golf clippers which is what i have please can someone make my xmas and help me solve this thanks for anyone that can help me out and merry xmas to all
Have you also checked the relay? This is what happened to mine when the relay had gone. Can't remember what number it is, but there's relay diagrams in the FAQ on here. Merry Christmas by the way
thanks for the reply geejah but if the relay was gone would the lights work cause mine do with hazard switch half on?
Hmmmmm, that I really don't know. Have to wait and see if anyone has any other ideas. So they blink correctly when it's switched halfway?
If you are stumped and want to try changing the relay give me a shout; I got a load of relays off ebay so will probably have a spare indicator one you could have for a couple of quid plus postage.
sounds good
that would be good geejah i could do that if you have paypal account thanks
Sounds like a dodgey wire to the switch, possibly a dodgey connector, make sure they are all connected properly, could be an earthing issue but immpossible to tell away from the car, hope that helps.
~Madferret
Mk1 1457cc 5door GX '83
Sorry, I've been away…still am so I can't double check if I have the relay or not. Should be back on the 2nd so just let me know if you have it sorted by then or if you still want the relay. All the best, Jonathan
I had similar twice. One was number 19 or 9 fuse (cant remember) and the other was a bad earth.
Im having the same problem... But my hazards work, just not the indicators... Ive changed my flasher unit... But no change... plz help
Having similar Problem. Green light is always dimly lit on the dash and the indicators dont work. The hazard lights work fine.
I have changed the switch to no avail.
Ive also noticed if I get the rocker on the Hazard switch to stay in between on and off (in the middle), then the indicators work again as above.
Im have a new Relay to swap on order, but suspect its an earth, but not sure where to look.
Any help aprieciated
Im sorted... It was the black/blue wire...
Schabzo said
Im sorted… It was the black/blue wire…
which black n blue wire ?
www.archwayvaleting.co.uk
the only black and blue wire there is
thats the ignition live feed for the switch
Thats the one... Its the only wire thats not part of the actual plug...
Schabzo said
Thats the one… Its the only wire thats not part of the actual plug…
this forum is just so so dope
just saved me a whole lotta heartache and made me feel more manly too
i'm still having problems with taking out the dash, so that i can remove the lower dash, so that I can replace the carpet
but i'm also thinking of dying it, black.
