gti clocks / fuel gauge
(In Topic #158740)
Got the GTI running and sweetly, only couple of issues,
1. the fuel gauge isn't working, have put £20 in and its not registering anything. (and i think the temp gauge isnt working but havent run it long enough to check)
I think the problem is with the sender unit itself (maybe sticky as its been empty for ages)
is there anything else that controls the gauges in the clocks?
thanks
thanks
here for a good time, not a long time
unplug the sender and bridge the pins, fuel gauge should go to full. its under the round black disc under the rear seat
seems a good thread for my little issue.
I don't remember my fuel gauge being such a pendulum.
Doesn't really hold station even when a fair amount of fuel has been put in. Should have about 15-20ls in at the mo but seems to hover around the red section. Having gone up to the first white line before retreating back to the red.
I do plan on putting a whole lot more fuel in tomorrow to see if it improves the needle and makes it settle down,
If both gauges aren't working properly then change then voltage regulator on the back of the clocks before you start messing with senders. Its a common fault.
my gauges will work with ignition on, but stop when running?
found my cause, bad earth ( i say bad, it was the wrong earth i was using),on the dash loom.
put it on a proper earthing point and it worked properly
