Fuse box/ fuel pump relay query
(In Topic #154218)
Mk1 gti 1.6 on a W. Unsure which is the correct fuel pump relay. Currently fitted with the type with an external fuse. It appears to have had the re-call/mod done at some point as the fuel pump relay is on a remote mounting. The fuse box is the type with a single row of euro style fuses, not the blade fuse type. Does this make it a series 1 fuse box??? and also should it have a relay with external fuse or without?
very grateful for any feedback/help!
Am only getting 3.8 volts at the power jumper thingy you mentioned. 12v going into the relay no problem, so i'm guessing or rather hoping its the relay at fault.
