fuel pump relay help
(In Topic #87198)
so i thought perhaps it was the fuse board corroded as well so stripped down the dash and changed the f/box…..still no joy
tried another relay ( but cant vouch for its state ) ……….still no joy
tried the bypass with the relay off and pump primes
is this a relay fault ? will changing relay for new one fix fault as it seems strange that the fuse corroded and the relay went at the same time, and other relay didnt work ( the car it came off was a bit finnicky with the fuel pump coming on anyway. have noticed wire for dashlights has melted ( a while ago )
any ideas people :dontknow:
83 1.5 gl all black sold
86 1.8 gti cab all black light mods. restoring
87 1.8gti cab standard helios blue. daily driver
91 1.8 auto cab gold clipper. breaking
Dave
relay
one thing , my battery has taken a pounding the last few days drained it etc but still turns over enough to start it with the relay by passed, but it doesnt so may try jumping it before setting off to get the relay
will let you all know how it turns out
still nothing
surely a corroded fuse wouldnt lead to all this ???
going to double check all the wiring again but it should have started
:roll:
no spark
found out i now have no spark at the ht leads or from the coil ( this was all working fine up til i broke down a few days ago)
perhaps there is still a unconnected wire left over from the old immobie that needs to be reconnected or earthed
any ideas :dontknow: :dontknow:
anyone :roll:
fuse boxes
Q. are there any differences in fuse boxes, apart from the relays which go on them ????
i couldnt see anything on it which differed to the other one and everything else works fine
going to strip the dash again tomorrow and see if i have missed anything
no joy still
stripped the dash again today and the ignition barrel, found nothing astray
changed coil………nothing
ignition switch unit swapped …..nothing
what else can cause no spark at the HT lead and to cause my fuel pump relay not to work :dontknow:
Use a multimeter and keep trying the wiring working back to the ignition switch and then the fuse box and eventually back to the battery - check all the earths are good.
Use a good wiring diagram whilst you do it.
Eventually you'll find somewhere where the 12v is not getting through.
Let us know how you get on
if so where ?
if not whats it got in its place ? as i have read thru so many articles etc and my old haynes doesnt cover the 18gti as well as it should ( for all you people that read it like the bible take note :roll: ) but does suggest my problem, if on a Gl , would be caused by the condensor in the distributor
come on rich you know this one :mrgreen:
by the way got any vent sets left ??
FIXED, 4 those with fuel/pump, ignition probs
was good to get the dash apart and clear up the old clatter of dead alarms/old speaker wires etc and to wire up the original 4 speakers
so for the many people that are having starting problems ie have no spark and fuel pump not priming etc, do what crazyquiff says and check the feed starting from the dizzy and work back from there
good luck all
thanks
If you do not have any power to the coil then the relay and pump will not operate too.
Bypassing the relay gets the pump running but there is still no pwer to the electrical side.
Glad all's running now
Rich
I just wanted to check before I really get stuck in.
Dave
red
it would be quicker and cheaper for me to type a lot of gibberish and you to say
'' f..k, how you supposed to understand that ?''
i would spend the ?15 on a multimeter…it would be of more use
if you already have one…air fresheners, car mats,furry dice :roll:
