Fuel pump fuse blown - help please
(In Topic #90794)
Hi,
My '83 GTi cut-out yesterday and I found that the fuel pump fuse had blown. I replaced it with another and it blew immediately on turn-over. Is this because the fuel pump is knackered?
Thanks!
Thanks!
Fuel pump
Had the same problem a while back, ended up it was bare wiring near the oil filter head , so check the wiring on the engine bay.
Thanks guys.
The car was 5 min back from having the cambelt and a couple of oil seals changed so I wondered if the mechanic had trapped the fuel pump wires as totenkpof suggested but I tried chudds sugestion (plus bypassing the relay with a jumper) and the fuse didn't blow which leaves the pump I guess…
Fuel pump fuse blowing - more help please!
Wierd the pump runs fine direct from the battery without blowing a 15A fuse. Any suggestions as to what might have caused the fuse to blow (bearing in mind that the fuse doesn't blow when the pump is disconnected from the loom)?
