Fuel pump constanly running
(In Topic #97002)
car is a mk1 with a 16v engine, it uses the early mk2 16v engine loom, into a late mk1 blade style fusebox, however the fuel pump is constantly running even with just the ignition on.
my question to you is, should the relays (specifically the fuel pump relay) on the fusebox be the mk2 16v relay or the mk1 relay?
Mk2 and MK1 pump relays are basically the same [excluding series 1 GTI] if your pump runs all the time i will wager that wiring / relay has been doctored to make it run with ignition on .
This by passes the coil pulse feature . In the event of a mishap [accident etc] the pump running all the time could be a safety issue . You can buy various cut off devises try Deamon Tweeks site .
2 types of relay that fit in the mk1/mk2 fuse box
if you look at the pins the colours of the base vary
brown base prime on ignition for 2 secs
white base only prime when cranking
obviously both prime while running
Sorry to put a spanner in it . Mine is black under and primes pre starting . I have a spare and thats the same . Article in Golf+ maq recently about these relays by 'The Brain' i will try and find it .
Cheers …………
newer ones may have been black
On all my FI Mk1s the pump has run constantly before starting the car.
what relays they got are they the brown base ones?
i was on the understanding the pump primes for 2 seconds then kicks in when cranking
Thats how i understood it should work, exactly like a mk2 16v does.
Primes for 2secs when you switch ignition on, then runs when cranking/running.
Not looked at the base of the relay, but its a 67 relay and is blue, this is what the mk2 16v used.
Life Member
Mine primes all the time too, but before I changed it, it used to prime for 2 seconds, anyone know where you can get the ones that prime for 2 seconds?
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
mk2 golf i think :wink:
Life Member
Well I phoned VAG earlier on, and they said they're dicontinued, which I would ahve guessed, GSF don't stock them anymore.. and apparently the MK2's have a seperate pin setup?
Shed some light please?
Follow us on:
Follow us on:
find one from a k-jet mk2 they are the same :wink:
Life Member
Cheers Ben
Follow us on:
Follow us on:
