fuel and temp gauge help !
(In Topic #86518)
The gauges work from a constant 12V via the fuse box, and variable resistance to ground through the senders.
The 12V constant voltage is definately the most probable if BOTH gauges don't work, as thier grounds are independent.
Mark.
so either a wire has come off rear of fusebox or the fault lies behind the clocks , i just hope its the wire off the fusebox .
many thanks
