Front indicators wont work!!
(In Topic #153585)
would this also work for sidelights to check the earth? (sorry to sort of high-jack your thread there TERRIBLEONE)Highwaystar said
Earth at the claw? Not sure which colour wire is earth but find out and run a wire from bulb to battery -ve. If they work you no it's earth issue.
'83 formel e
Yes same principle
'83 formel e
Highwaystar said
If u had loom out maybe missed an earth? A wire to be screwed to body? If stuck you can run a new earth to battery 've- The claw or the body but try and keep your wire's tidy
Hello mate. Any idea what point i should take an additional earth from? I held the temporary wire on the blue wired terminal of the drivers side indicator but there's not really any way of tapping in to it. The passenger side appears to have an earth attached to the indicators bulb holder. I guess i should trace it's path and clean up its end/ take it to the -ve terminal and hope this is the offender? I'll take a look in the daylight tomorrow, i'm sure it'll be straight forward enough. Thanks again. Ben.
