fog light switch wires
(In Topic #143869)
83 - grey/yellow - power from headlight switch
83a - white/yellow - front fog power (if fitted)
83b - grey/white - rear fog power to rear fuse above fusebox
I dont have my mk1 haynes to hand but looking at early mk2 the fog power input comes from M/1 on the back of the fusebox, which in turn is fed from A/9 on the fusebox which in turn is fed from the headlight switch.
follow the wire from pin 83 on the switch all the way back to where it comes from hopefully there will be something obvious there
As Johnny states it's fuse is in it's own holder above the fusebox it's self and not on the main board, have you checked the 10A fuse, to see if that's gone? Plus these have a habbit of water ingress and the bulb holder terminals going cruddy, try cleaning these up too.
My horn stopped working and all it was the old relay contacts were really mucky, so quick rub down with some sand paper cured it.
I think this pic will help
the warning light will only come on when the rear fogs are switched on
start at the fog switch and follow the grey/yellow
I open this old topic because I have exactly the same problem, may i ask which wire it was? i have no power on my rear fog light and i have no power on both wires from the top fuse, where do i start? I also have no power on any of the wires of my fog light switch (except the grey/blue for the lighting switch light.
This is the one without front fog light and its the mk1 golf GTI 1983, I have several books with small wiring diagrams but all the colors don't match. when I read this topic it seems exactly the same wires as my fog switch, Anny idea?
Thanx a lot Paul
Last edit: by Paukus
