Flat battery!!!!!
(In Topic #78129)
Flat battery!!!!!
Mike.
1983 White cabriolet GTi
Also with a good set of jump leads you should be able to jump start the car even with a completely flat battery. Check your connections on the jump leads when you try and make sure they are good, and that the jump leads are man enough for the job (if they are getting hot when you try and start the golf, then they are probably too thin)
Mike.
should be 13.5-14v with the engine on, and about 12v off,
tim
mk2 1.8 Driver
mk1 1.8 16v on Carbs
stafbt said
…. i cant even start it from another car. ….
…this suggests to me that you have a bad connection somewhere…..battery earth lead where it's bolted to the body/chassis…..connections at the starter solenoid….?????
1983 lhasa green GTI
1982 lemon yellow CL
