Fan blowers, strange problem????
(In Topic #128770)
Mainly go off when i corner right but dont come back on till i switch off and leave over night?!?!
Most of the time they only work for a couple of mins then die not to start agin till the next morning.
Anyone got any ideas?
I ended up taking my switch to bits and bodging it a bit to improve the electrical contact.
This is easily tested by pushing the switch in when you have any one of the three speeds selected, it should work until you take pressure off the switch.
If its not your switch you might have loose a connection somewhere, the fusebox's are pretty bad on the mk1, I've ended up wiring my blower switch directly to the battery.
If your worried that your fan might be on its way out then just get a length of wire and connect the positive connection of the fan to the battery directly, if it runs up and stays running then your fans fine.
06 Audi A3 (Wifes daily)
Or pm funkstar on here, he will probably have one knocking about too.
I squirted wd40 into the fan motor and after about half an hour of stop starting it's now running perfectly
