Electrical Gremlins!
(In Topic #135016)
Here are some of the gremlins I have.
When I go to put main beam on there is no Clicking noise or dash warning light and there is no main beam!..Does this mean the relay is :dontknow: kaput?.Also when I operate the main beam the drivers side light goes onto sidelight only!! :dontknow:
Also the indicators and hazards when operated flash slow and dim!
This to me looks like a bad earth but I just wanted to tap into the forums knowledge so that I don't go barking up the wrong tree!
Sean
Your always going to get these niggly little faults with electrics after somethings been standing for a while its just a case of ironing them all out!
06 Audi A3 (Wifes daily)
I started with cleaning and renewing all the earth connections.Then I checked the fuses and cleaned up the spades. After a check of the relays and a bit of swapping about we had success. All the lights, indicaters work, the only thing still to sort is the horn and one of the rear fog lights. Will have to read up more about the horn in the forum but with the rear fog I think I will try shortening the connecting wire between the two(shouldn't be that long surely!)
Once a replacement light switch is fitted(the old one is a bit suspect) and the new rear brake pressure regulator we will be closer to mot time! 8O
Check first if you have 12v on the black on yellow wire at the horn with the ignition on,
if you do you need to find the black on brown wire at the steering column were it runs into the combi switch
and earth the wire and see if the horn works if it doesn't then there is a break in the black on brown wire to the horn
or the connections need taking off and cleaning up
if it does then you have a faulty horn plate or a faulty earth wire to the steering column/rack
Matt
