Electric problems
(In Topic #99965)
Electric problems
Car has had fuel flushed out and fresh put in, new dizzy, cap, arm, leads, plugs, fuel pump ok, fuel lines ok,
Had problems with starting but can now get it started,
But i have to turn the car over, rev it up, turn ignition off then on quickly and then the car idles and runs ok,
If i just turn it over normally, it idles for a couple of seconds (if that) then cuts dead, rev counter drops to '0' and car dies, same as turning off with key, not a gradual cut out,
Fuse box is a right mess, wires everywhere, if i clip the fusebox back up under dash car turns over but will not fire up, so its making me think theres a problem in this area,
What relays/fuses/ wiring/connectors do i need to look at ?
Any links to wiring diagrams ?
I would get a haynes manual but its says it doesnt cover convertible, so i dont want to waste another ?15 ! lol
1989 MK1 VW Golf GTi Cabriolet, 'All White Edition' - currently having a new blue roof fitted. Yes it's not white but it requires less Cif to clean
Some of the terminals in the fusebox look a little corroded so might try and get another one,
