Economy guage??
(In Topic #80135)
Economy guage??
What does this do and how does it work?? Should it just be the orange light or needle aswell??
ops:
See you at the shows!!
orange light should come on in every gear to indicate the correct time to change up ( for economy ) the needle should only work in 5th gear to show instant consumption.
Nether of these work on my series 2 though
( the rest of the mfa in fine )
I have the needle that comes up in 5th gear after about 45 secs but no orange light or MFA! Screen is blank :dontknow:
Cheers,
Liam
Liam
Never seen the light or the needle! MFA won't reset, oil temp works, but it tells me external temp is -40 (even today) and that i'm averaging 10.2 MPG!!
'85 GTi Cabriolet
'80 Kawasaki KDX 175
'93 Kawasaki ZZR 600
'97 Chrysler Grand Voyager
My MFA works fine and so does the orange light!! 8)
No needle in 5th though!! :cry:
Check the switch on the gearbox (combined with the reversing light switch) and it's wiring. This activates the needle when you select 5th.
I'll check that one out, thanks stew72. I have a wire poking out of the loom and not going anywhere, i wonder if the other half is attached to the gearbox?
:dontknow:
:dontknow:
'85 GTi Cabriolet
My economy gauge didn't work until I connected the tube that runs from the vacum advance to the back of the throttle body now works perfectly. Everything on the MFA works except fuel consumption is wrong. Changed the oil on Friday and ever since the oil temp won't come up any ideas?
MK1 GTI 1983 (love of my life)
Mazda MX3 1.8 V6 ( Daily Drive)
mines the same MFA won't reset, front bumper sensor is at -40 but the rest is fine - the needle works…. where is the light supposed to be?? I tend to change up when the rev counter needle hits the red bit on the dial
mine works perfectly :mrgreen:
had one of those rare occasions today when my fuel and temp gauges were working. Checked the MFA - wouldn't reset, but everything was working
dash is coming out at the weekend to fit new headunit, so i'll be having a poke around!
'85 GTi Cabriolet
