DX to ABF engine wiring loom conversion
(In Topic #141145)
I'm going to have a go at converting my ABF k-jet back to ABF Management.
I've got hold of a DX engine loom obviously for the fuse box connector and I have the ABF wiring loom also. A little bit lost and not really sure where to start so feel free to chip in ;-)
I have started stripping the ABF loom down and started trying to label some of the plug connectors so I know what I do and don't need.
ABF engine loom.
ABF ECU connection and other wires
The mess.
So… What exactly am I to chop?
Do i only need the wires that would go into this connection on the engine loom
If anyone knows please let me know. Thanks alot
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=100988
but yeah 1st thing is strip both looms of their outer covers, put a bit of tape every foot or so, that way they keep their shape (bit late for you it seems
you can bin the carbon canister which is the green/yellow and brown/blue plug, near the lambda, also the outside air temp red/wht and brn/wht.
plus theres a plug on the bit of loom on the engine which has a brown and black wire for the breather heater that can go too. when you find the 3 pin plug to the mk3 coil, chop that off too and bin the black and brown wires. keep the green/red you'll need this later. once the battery earth is gone you will have an earth for the ecu, leave this too we'll deal with it later.
next step is to lay the looms in the bay and adjust till you are happy with the abf routing, then tape it to the mk1 loom. remove frm the bay and adjust as necessary, then start joining your ends up! the oil/temp sensor wires are easy just match the colours. behind the fusebox you'll have a purple/white wire which is the mk3 dash mpg signal so that can go, a blue/white wire which is speedo signal again unused. the rev counter wire is green/white to G1/12, this wont work with mk1 clocks so leave that, use the mk1 coil wires instead. the grey/white wire is your diagnostics, keep that for when you wire in the vag-com port.
get your tci loom and put that near the ecu, splice the green/red wire from the old mk3 coil plug to the wire to the tci pin 6. next bare a bit of wire from the wire to the battery -ve, wrap the abf ecu brown wire round this and secure with solder then tape up. replace the ring terminal on this -ve lead if its looking grotty.
for the rest of the fusebox wires see the linky above!
DX to ABF
Thanks for the reply.
Just having a look at it now, I must say, I've ballsed up big time by not wrapping the loom up every foot or so :-(
Anyway, I'm going to start chopping the loom now so I can start working. What are the two big fat double chore wires used for?D
DX to ABF
Made a little progress last night. I managed to strip the loom right back and removed all of the none ECU wires (I think)
I'm left now with many wires that need a home.
I have no numbers but I did take pictures and have the colours, maybe you could advise me if they need to be cut and binned or you know where they need mating to?
1. Brown wire, goes from ECU plug and went to a series of earths on a connector.
Battery earth for ECU?
2. Brown connector 3 pin. Yellow-white-black wires. Goes straight to ECU plug
3.Black connector, 3 pin, grey-blue-black wires. Straight to ECU.
4. A yellow and a white wire twisted together. Goes from ECU plug to 4 pin connector at fuse box end yellow-white-red/white-brown
1. see my post above in the section about the tci conversion
2/3. knock sensors
4. lambda probe (what did you cut those wires for? silly boy
there should be another 2 pin plug near the lambda for the inlet temp sensor, wire colours white/yel and brown/blue
DX to ABF
There are loads more wires and plug to sort out. Any chance you could keep helping me?
DX to ABF
6. 2 pin, red/white wire - brown/white
7. 2x 2 pin yellow/green - black/white
Yellow/white - brown/blue
8. 3 pin, purple/white, black/white, green, black
9. 2 pin, blue/brown - brown
10. 6 pin connector with 4 wires
Red (thick battery wire) yellow/black, brown/black, brown / black
11. Single yellow connector with black/yellow wire
12. Single blue connector with blue/white wire
Don't get me wrong, I've read through the added link a few times and it has helped but it is slightly above me at the moment as I don't have any fuse box in front of me so some stuff makes no sense at all at the moment.
Cheers Rubjonny
DX to ABF
DX to ABF
6. outside temp sensor -> bin
7. yel/grn & blk/wht is the carbon canister purge valve -> bin
yel/whit and brn/blue is the inlet air temp sensor -> keep
8. mk3 dash plug -> bin
9. brake fluid level -> bin
10. rad fan control unit -> bin (keep mk1 rad+fan and use the wires for it on the mk1 lighting loom)
11. for the rad fan control unit, this will be binned along with plug 10 above
12. ecu speedo signal -> bin
with the diagnostics wire 1 find a post-96 mk3 in the scrappy and find vag-com port behind the slidey panel next to the ashtray. trace the wires back and remove without cutting the grey and yellow wires, cut the red/white and brown off with as much length as you can, these you splice to your ciggy lighter wiring or any live and earth back there. once you find the end of the grey and yel wires you'll see they plug into a jumper block above the fusebox, take that as well.
btw, this is a later loom so it will have an immobiliser if the ecu came with the same car as the loom. do you have any of the interior loom? you'll want the immob box with the matched key. plus the key reader coil from the ign lock and the wiring for the immob box but its dead easy to wire in. it will have an earth and a black wire which is ign live, then a wire to the plug 1 above and another wire to the diagnostics jumper block.
you'll want to buy a new crank sensor:
http://www.vwsonline.co.uk/car_parts_bristol/037-906-433a.html
id recommend a new ecu temp sensor from vw too but thats your call
DX to ABF
DX to ABF
Cheers bud.
Thanks again
crank sensors are service items, so if its the original chances are it'll need replacing. its just about the only thing that'll stop an abf running so its really in your best interest to replace it, especially as they are so cheap
DX to ABF
Is this what you mean? I didn't get all of that.
ecu -> immob matching is easy, but immob -> chip matching is not. if you dont have a matched chip only vw can sort this out for you, but if you have a matched pair then you're away.
most other vw/seat from 96 to around 2000ish use the same system as the mk3, to give you more cars to pinch from. note that from 98 on the immob box plugs changed shape, but they're still compatible (just make sure you get the right loom to match!)
HTH!
DX to ABF
Transponder, chip out of the key from the mk3 and the box?
