Drivers side rear Indicator stopped working.....
(In Topic #109307)
Car is a 1983 Tintop.
The driver?s side rear indicator has stopped working.
Everything else is working OK
I replaced the bulb, no joy, thinking it was the light board, I tried the passenger side rear one (which I know is working) and no joy.
I checked the earths in the rear boot and under the slam panel ? no joy.
I presume the indicator stalk is OK as the drivers side front indicator is working OK.
I presume that the hazard light switch is OK as the other 3 indicators are working.
Another issue, which may or may not be related, is that when I press the brake pedal, the passenger side front side-light comes on. The brakes switch is a sirocco unit mounted on the steering column.
Everything was working OK up to this point.
Any ideas of what next to check next, much appreciated.
Thanks, Michael
Faulty rear brake / side light bulb
Bulb holder , centre pin that bulb sits on will be bent and not making a contact .
Cheers, Michael
~Madferret
Mk1 1457cc 5door GX '83
Brake light bulb faulty, so side light issue sorted with new bulb.
Gonna buy a multimeter tester, but not exactly what to do with it :dontknow: I suppose stick it in wire at rear of bulb holder and see if I get reading?
