Drivers side rear Indicator stopped working.....
(In Topic #109307)
Morning lads,
Car is a 1983 Tintop.
The driver?s side rear indicator has stopped working.
Everything else is working OK
I replaced the bulb, no joy, thinking it was the light board, I tried the passenger side rear one (which I know is working) and no joy.
I checked the earths in the rear boot and under the slam panel ? no joy.
I presume the indicator stalk is OK as the drivers side front indicator is working OK.
I presume that the hazard light switch is OK as the other 3 indicators are working.
Another issue, which may or may not be related, is that when I press the brake pedal, the passenger side front side-light comes on. The brakes switch is a sirocco unit mounted on the steering column.
Everything was working OK up to this point.
Any ideas of what next to check next, much appreciated.
Thanks, Michael
Thanks, Michael
Faulty rear brake / side light bulb
Bulb holder , centre pin that bulb sits on will be bent and not making a contact .
Great, Thanks for the reply Chudd, I will check these tonight.
Cheers, Michael
Cheers, Michael
Could be the stop/tail bulb is incorrectly inserted too
~Madferret
Mk1 1457cc 5door GX '83
Checked last night - bulb is seating ok and making good contact with centre pin, but still no joy….
Brake light bulb faulty, so side light issue sorted with new bulb.
Gonna buy a multimeter tester, but not exactly what to do with it :dontknow: I suppose stick it in wire at rear of bulb holder and see if I get reading?
