DIY Wiring
(In Topic #156052)
1.6 EG 1980 fuel pump relay wiring - should I have a go??
check plug A on the back of the fusebox too, maybe the fuel pump power pin has burnt out (see fusebox sticky, early ceramic fusebox)
to add another relay is pretty simple, get a decent vw relay holder and you can tap into the engine loom wires. tap into the thin red/black to pin C/19 for rev counter feed, G/3 spade for ignition live, one of the H spades for live and run the output to the 3 pin spade connector near the C pillar
