Dipped beam problem
(In Topic #87442)
Dipped beam problem
Got a problem with the old dipped beam
Side lights work
Main beam works
I've read through all the light posts I could find and found reference to a problem with a rev counter, mine keeps doing odd stuff and that turned out to be the earth so i'm off to find/check that now. there is also mention to the main beam stalk, washer stalk, fuse box and so on so i'm a bit lost at where to start.
I have a trickle of voltage to the fuse and at the lights when ignition on and not when off so is that consitent with a short somewhere?
Any thought's appreciated
matt
I have fixed it, I think that it may have been a dodgy switch as I had it to bits earlier, took me a good 15mins to find the 7 springs that flew out when I took it to bits and get it back together. I gave it a bit of a wiggle and hey presto!!!! Might be time for a new switch as it's not something i'd enjoy doing at night.
those of you going this weekend see you there with lights!!!!!
mattt
