Digital clock bulb?? Help please!
(In Topic #106454)
I have just removed the clocks from my 1991 clipper to change the bulb above the speedo which had blown. The light above the rev counter was fine.
What I need to know is where is the digital clock bulb located since this has gone as well?
On the back of my clocks there are three bulbs, 1 above the speedo, 1 above the rev counter and 1 on the centre in the back - is this rear centre bulb where the digital clock get's light from or is there some other concealed bulb for this?
Help gratefully appreciated!
Thanks.
Thanks.
Anyone?
Also where the heck do you get the bulbs for teh headlight switch from?
Bulb issues!!!!!
Bulb issues!!!!!
Member 125 - 2005
try main stealers, i also seem to remember the ones they sell nowadays are also a little brighter.
They're all the same for the dash clocks. The white plastic capped bulbs are 2w each and the black 1.2w I think - so upgrade to the white versions.
Yes - the centre one does do the digital clock.
I think the bulb is replaceable for that switch - It's a tiny push fit one. Will try to remember which it is….
1990 MX5 Mazda
2003 VW Passat 130 Sport
Sylva Fury 'blade powered…
Cheers guys, you've told me everything I needed to know!
Just been out teh car and taken out the bulb for the switch to see which one it is. For the record this is the link to the replacement:
http://www.autobulbsdi…v-12w-black-pr-16930.html
