diesel loom swap
(In Topic #156485)
im just researching dong a diesel conversion on my 83 1.1, It needs to look factory fitted, am I right in thinking the engine loom from a caddy just plug straight into the fuse box? if so are all mk1 caddy fuse boxes the same? and are the connections there for an aaz?
thanks in advance
thanks in advance
all mk1 caddy use the later blade fusebox, if this is what you have in your mk1 then yes any caddy loom will do
