dash probs
(In Topic #93278)
dash probs
all dash electrics seem to work fine until the lights are turned on, then dash lights go out and the mfa and rev counterstop working, sometimes the indicator relay clicks flat out even when not indicating.
have removed fuse box and all seems clean, re terminated earths situated by the fuse box.
All exterior electrics work fine.
the large white plug to fuse box seemed a little corroded but have cleaned, not sure if well enough though.
seems hard to comment on but any ideas, i have replaced the light switch,
is it possible the instrument cluster is at fault?
cheers jay
cheers jay
there's an earth behind the dash… could be that :dontknow:
does sound like a dodgy earth problem to me though
is that the earth cluster right next to the fuse box, or is there another one somewhere else?
cheers jay
cheers jay
another one, it's behind the dash clocks somewhere
just recall some people having issues due to this
cheers i'll have another look
Try this - I had this problem on mine, it was the small earth wire that is attached to the Rocker cover had come off.
89 MK1 GTI Cab ( Helios Blue ), 64 reg VW Transporter T30 highline, Audi A1 1.4 TFSI Sportline..
