Dash loom wiring help needed.
(In Topic #152959)
Firstly this green and white wire with a male spade, doesn't appear to have a home yet. Any ideas?
Next, is this one that has been cut, yellow and white. Anyone know it's purpose, there is a corresponding wire that could be re-joined but not sure if it was done for good reason?
Also, have a bundle of grey and yellow, this was bundled on old loom and has been cut on the new one, so again could be joined but, i don't know it's purpose?
Finally, for now… the remaining stragglers seem to be lending themselves to the back of the heated rear screen switch, but the block, two of the smaller connectors are in doesn't quite have the correct spacing to fit, i assume it may have been a slightly different switch, should i just lose the block and connect them straight up; if so, could anyone hazard a guess which order the four connectors should go on the the heated screen switch?
Sorry the pictures are poor, but hopefully someone may be able to make some sense of this. Thanks for looking.
http://www.edition38.com/forums/index.php?showtopic=174707
For Any Wiring Need Uprated Headlight Wiring Looms, Heated Seat Looms To Smooth Bay & Full Car Looms PM For Details
Visit Our New Shop @ www.RayneAutomotive.co.uk
Jamesw153 said
I use this thread a lot when wiring things up, might be of use to you.
Thanks mate, from this and Chudd's guide, i'm pretty sure, the white and yellow is the fog light's but cant seem to match the others yet. Could anyone confirm wether b2 (red 28 pin block) should read as grey and white as opposed to the green and white it's showing in Chudd's faq guide? Thanks to Chudd and rubjohnny for their info.
