dash lights again
(In Topic #97029)
dash lights again
the wiring in my car has badly been tampered with in the past so eventually i intend to completely remove the dash and go thru it all methodically to make everything work again, ive been lookin at the haynes manual all day and its makin my head spin. just so u no, this is wot ive got to work with
also its a 1990 cabby if it helps, thanks for ur help, macca
Re: dash lights again
Don't blame you ! Your pic shows fuze 19 missing :dontknow:
If it was me i would remove all items not supposed to be there and start from scratch
Cheers ………….
that wud be why my leccy windows dont work then!
so update is ive fixed all but the lights for the dials, heater controls light up, and dimmer switch works but no dials yet, so presumably that just leaves the bulds to check?
Mine failed and I had to cut that part of the plug off and rewire with a small female spade connector to go on to the switch.
The voltage will vary dependant on the position of the dimmer wheel/rheostat, from about 6 volts up to battery voltage.
Check you have voltage at the switch terminal, then follow the brown/white wire from there.
I'm certainly no electrics whizz, but with help have discovered this recently.
Hope this helps.
Jon
so, where can i get the replacement bulbs from, as the dimmer back light bulb has blown too so the switch dont light up and on it has vw and audi rings logo on it, do i hav to go to vw or wud halfrauds suffice?
pic of the bulb:
You could try these people;
http://www.autobulbsdirect.co.uk/home.php?cat=588
Web Team
