Cold Start Valve
(In Topic #84517)
Cold Start Valve
Having issues start up from cold. I've checked the cold start valve and petrol is being delivered. I've removed the start valve and turned it over and it doesn't spray. I replaced the start valve and still doesn't work
Where do I go from here
Re: Cold Start Valve
spengticab said
Help!!!!!!!!!
Having issues start up from cold. I've checked the cold start valve and petrol is being delivered. I've removed the start valve and turned it over and it doesn't spray. I replaced the start valve and still doesn't work![]()
Its an electrical injector, check the plug has +12V when the starter turns. If not, then it could be the thermo time switch, this supplies the voltage for an amount of time, which varies according to the temperature.
Seems strange no power to any, where should I start to Look??
The blue one looks like it's been ripped from somewhere and not cut anyone know where this blue wire is from!! and cloud it have anything to do with the cold start problem.
The two red wires go from the alternator to the starter motor solenoid.
The blue wire goes from the alternator to………………the alternator warning light in the dash.
This light goes out when the alternator generates above a certain voltage - not sure what that voltage is though
Ali Cabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
