Cold Start Injector, thermo switch
(In Topic #75029)
Why am I looking because the car takes numorous cranks to start when cold, fine after that :dontknow:
If you have your haynes handy please help
Rob
Audi A4 1.9TDI - Gone
Cold start injector is located on the far right of the inlet manifold and the thermotime switch is at the end of the top radiator, both should have blue plugs, but iam unsure of the colour of the wires
far right
Only if you are looking at the engine standing on your roof.
I tend to find it on the left of the inlet manifold.
As for the original question, I would stake my last can of beer that the cold start injector isn't your problem.
I have had mine unplugged for a year now because if they go funny they can muck up warm starting.
Anway theres lots of info already on the forum if you give it a good search.
Peter.
1980 1600 GTI, daily driver.
oops…yea only if your standing on the roof
any ideas looks very odd? any ideas what might be causing the excessive cranking?
Rob
Must be a later cab thing, never seen a sender over the inlet manifold! darned fangled cars.
Lack of a reliable partner?
Excessive cranking is bad electrics or injectors dripping fuel and flooding the engine.
Peter.
I don't think it''s extra fuel as a little throttle helps! must be wires. I do need to clean up connections as they are looking a little coroded, the wash motor stopped because of poor connections, so there may be more. In the last service by P.O. it had new fuel lines and a new pump, so all should be well there hopefully.
I've got a haynes manual comming, so all maybe rrevealed soon
Can do it all yourself aswell. Just be patient and get the leads back in the same order you take them off.
Theres plenty of posts on this stuff use the search function.
You'll be sorted for the winter then.
Peter.
Big
The sensor thing sounds feasable but can't find an un-attached wire any where. which way round does it sense to hot open or closed, would explain if the other wire shown has been tied to ground to bypass it.
Rob
