clock / instrument cluster removal?
(In Topic #91494)
Hey
I've tried a search but not come up with anything…
I was wondering, how do I remove the instrument panel from a 83 GTi? I've got the dash surround off and taken out the 2 screws that hold it in place but I'm unsure as to how to remove the cluster? Haynes is useless!
Basically, I've got the oil buzzer / light problem and I'm trying to find out why. I had a look around but couldn't work out where the buzzer is located or where the earth is for it (seems to be the common problem) so perhaps if anyone knows where they are I won't need to remove the clocks?
Cheers in advance
Adrian
Cheers in advance
Adrian
<a href="http://www.demonvw.co.uk/forum/viewtopic.php?t=14992">My MK1 GTi</a>
Web Team
Reach behind the clocks and disconnect the speedo cable. Rotate the clockset forwards from the top then lift out slightly and disconnect the mutipin plug from along the bottom. Should come out then. Go easy with the speedo cable, can be a bit brittle if old.
Presume the oil pressure is correct and not low, and the sensors are in gwo.
Tell me about it.
Tian
Web Team
All senders from the engine is fine, my VDO gauges read fine but still get the buzzer, we have the clocks out and apart but I've no idea what I'm ment to be looking for?? where is the buzzer and what does it look like?
Damn Haynes! lol
Damn Haynes! lol
Disconnect the senders and keep an eye out on the gauge
Senders new?
Senders new?
Web Team
It seems to usually be a fault in the circuit board or the earth. Fortunately never had this prob myself. Have a read of THIS, should help you a bit further. Quite a few links to various discussions in the electrical FAQ.
Buzzer is on circuit board 14 below…..a copper wound coil with a flap at the end - stick it with bluetac or similar….BUT MAKE YOUR OIL PRESSURE GUAGE IS WORKING….
