clipper headlight loom smoke and melted cables
(In Topic #158798)
- ive lost the interior lights on the dash but my window and hood ones still light up
- ive changed from a quad light set up to a twin and not changed the wiring, cables arnt touching tho
- My mate thought my lights went out after going over a pot hole ten mins before the burn out but the lights was still working
- Does anyone know what the cable does?ive been trying to make sense of the haynes manuals and stuff online but cant find a diagram for my car but cant find the colour code that matches what ive got
mk1 clipper
mk4 gt tdi
mk4 gt tdi
was it from pin 56 on the headlight switch? if so the black/white wires are the dip/main power feed to the flasher switch in the stalk, chop out all the red wire bodgery and crispy bits then fix it up nice. you dont need to run this wire to the fusebox at all, just run it direct to the stalk. the fusebox wire is used for headlight washer system, so unless you have this you can just bin it
mk1 clipper
mk4 gt tdi
mk4 gt tdi
but be sure to check the blue/grey wires in the dash for damage, could have been taken out when the other sections melted!
ordered a new switch incase its the dimmer thats gone wrong.
thanks rubjonny will do that if the switch doesnt fix it
mk1 clipper
mk4 gt tdi
mk4 gt tdi
