Changing reversre light switch
(In Topic #89322)
Has anyone done this before got any tips. Haven't had a proper look at it yet because in the middle of other jobs. Is it allen key bolts, can't quite tell? If so what size?
Hi,
I changed mine a couple of months back. There is a thread on here that says that it is quite tricky. Not for me. I got the part from GSF and then took it off using allen keys. Fairly easy - just need to move the air box where the air filter is housed - makes it easier. Off with the old one and on with the new. Just check the old one and make sure the wires/pins match up. Othersie you may need to move some pins around and that is where the other thread will come in handy.
Good luck!
Good luck!
