Can anyone identify....with pics
(In Topic #94539)
obviously the bigger plug of the three is for the clocks, the other two come out of the same section of loom but unsure what they plug into, any ideas?
i've replaced the old '82 loom (bullet style fusebox) with a late '90 cabby loom, the early loom doesnt have those extra plugs, but everything else is the same apart from needing a newer syle headlight switch as the plugs are slightly different
some of the looms on later cars had different connectors to the early cars, i have had all versions of Gti mk1 and they have all been slightly different in some way or another
You dont happen to have any spare connectors that go to speakers in the door do you?
Worth a shot.
VW Golf Mk1 Cabriolet - Rivage In-Build. Again.
Chairman
Dan (tired and want to go home… roll on 4am and no jobs!!)
Re: Can anyone identify....with pics
Light feed to facia panel , heater . [black plug] White plug MFA feed left bottom of clocks .
[You could chop those MFA wires back to the fuze board , thats where they all terminate .]
Brown wire on large plug , earth it , it was for Mfa function and used to be earthed on the rocker cover .
Haynes Manual [green cover] for MK2 Golf has better wiring diagram for more info .
…i'll trace the wires back tomorrow in the light and see whereabouts they come from,
T14
1 - blu/gry - Lights on feed
2 - brn - Earth
3 - pur/blk - Fusebox pin B/3 (fuel level sender)
4 - blu/yel - Fusebox pin B/7 (coolant temp sensor)
5 - red/blk - Fusebox pin B/19 (rev counter)
6 - red - Fusebox pin B/12 (permanent live)
7 - blu/wht - Fusebox pin A/28 (high beam warning)
8 - brn/wht - MFA switch mode button
9 - yel - Fusebox pin A/4 (high oil pressure warning switch) (blk/blu on early models)
10- brn/red
11- blu/blk - low oil pressure warning warning switch (yel on early models)
12- blu - Fusebox pin A/16 (alternator warning light)
13- blu/red - Fusebox pin A/17 (indicator warning lamp)
14- blk - Fusebox pin A/8 (ignition live feed)
T6
1 - wht/blu - outside air temp sensor
2 - wht/red - outside air temp sensor
3 - grn/blk - Fusebox pin B/15 (oil temp sensor)
4 - blk/yel - Fusebox pin A/3 (Gearshift control relay pin 3/L)
5 - wht/grn - Fusebox pin B/18 (Gearshift control relay pin 5/G)
6 - wht/yel - speedo signal
T2b
blk/wht - MFA switch memory button
red/wht - MFA switch reset button
