Campaign dash lighting
(In Topic #72143)
Grnted some of the switch bulbs need replacing, but can anyone tell me is the MFA display supposed to be backlit? I really couldn't read it at all in the dark. Just curious to know if the LCD panel should be backlit or if one of my instrument bulbs has gone that would otherwise make this visible at night.
I also found out that the hazard warning switch I have is not original, if anyone has one that would have been an original fit for a Campaign I'd appreciate knowing about it.
Cheers,
Chris
Life Member
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
I may have a switch i'll have a look tomorrow, u can get 2 watt replacement bulbs for the instrument panel part no. 431 919 040 A, They have a white base
Wellsy
1983 MK1 Golf GTI (Campaign?)
1983 MK1 Golf GTI (Gone to VW Heaven)
1990 MK2 Golf GTI G60 Edition One
Otherwise I'll have to add it to my parts list for a trip to Rich's "friendly" VW dealer sometime in the next week or so
Let me know if you turn something up on the hazrad switch and maybe I can get along to one of the local VDub meets you and Dave were mentioning to collect?
I was amazed at how many later VW stable cars have same/similar switch gear to the MK1. I got new fog light switch for mine off a polo.
My brother got recently an L-Reg Polo. I was amazed too in that how many parts look very similar to my MK1 - especially trim wise. Even his boot floor mat is made of same material as the MK1. Unfortunately, (fortunate for him coz I'd pinch it!
Evidently some of the later switches used on other cars look virtually identical, but have subtle differences like the little amber light in the switch is on the other side to the original Mk1 ones.
I'm still on the lookout for another DX head to stash away. Only thing I have found though is that most of the VW specific scrappies / dismantlers seem to want crazy money for used parts :roll:
As i had my car off the road for 3 years when i put it back on i thought the dash lights were very dim.
Ive checked and all the bulbs (except foglight switch) are working but the dash seems very dull lit, it hardly lightens up the display (not very bright on full setting and dark on the lowest) compared to other cars.
Is it just i cannot remember how dull it was before and the display is very dull anyway? or is there an earth thats not got a good contact?
Any thoughts?
Geoff.
GTI Campaign owned since 91 + GTI mk6
Also maybe check the dimmer switch itself - can you unplug it an remove it from the circuit, then try a spare from another car - there must be loads around as I think its a common part, most VW scrappys probably have one for well under a quid.
I find my dash quite readable, but it isn't as bright as more modern cars. MAybe its just a "feature" of cars of that era? I didn't realise the MFA display was supposed to be backlit - once I have that sorted I think it will make a big difference.
Cheers,
Chris
I think i will try changing the dimmer i should have one somewere if not a mates scrapping his old passat that has the same switches ive told him im pinching before its scrapped.
ChrisB said
…. some of the later switches used on other cars look virtually identical, but have subtle differences like the little amber light in the switch is on the other side to the original Mk1 ones
The deal with these is that up to the end of the '82 model year (C - VIN), RHD Golfs and Polos were still being fitted with LHD switches (when the function logo is the right way up, the tell-tale (the amber light) points at the LHD driver).
From '83 model year on (D - VIN) new Golfs (and the others) were fitted with re-designed RHD switches (tell-tale points at RHD driver)
The problem with mine, I think, is that the earth strip on the printed circuit behind the instrument pod appears to have burnt at some time (some previous idiot had put incorrect bulbs in the supplementary guages). Will try to 'fix' it this weekend by soldering a wire in place. If that cures it either get a correct printed circuit from a scrappy, or one from VAG (?60 + the dreaded)
I wonder if that stuff you can get for fixing rear window demisters could be used for fixing PCBs?
Just checked it out and it can…
http://www.partsforsaa…_info.php?products_id=137
I'm sure I saw a cheaper one in Halfords.
Peter
1980 1600 GTI, daily driver.
