Cabbie Hood Hydraulic question
(In Topic #85435)
I had a scan through the forumand found some items regarding this but nothing specific (big forum, lots of posts). I have a 90 Cabbie and I cant seem to get the roof down using the power button. I have the key in the O position, engine not running etc, pop the release handles and nothing happens. The motor clicks but nothing more, I have undone the key release and opened th hood manually and checked the fluid levels. IN the up position the levels are bang on midway between the max and min, in the open position it is about an inch over the max…. what can I do and where do I start looking.
Les :dontknow:
Danny
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
Hopefully the following pdf's will help a bit…
http://www.vwgolfmk1.i…hood/Powerhoodcircuit.pdf
http://www.vwgolfmk1.info/Powerhood/Powerhood.pdf
Cheers,
Ross
Any thoughts about the fluid levels ? is it worth just raising and lowering the roof manually a couple of time and re checking it?
Nomad said
….. getting a new hood fitted soon …
…check out your rear window frame….see our Hood Saga
Nomad said
……. I already have a new mohair hood and side cables.
…as you already have these , and if you want to do it yourself, have a read of the following excellent guide by Ross:
Hood_Replacement_lo_res
Hood_Replacement_hi_res (3.2Mb)
