Burnt out! is it safe to drive
(In Topic #91795)
Bugger need new loom would it be safe to still drive as it still does
1983 GTI-Black
MY very first one AND LOVING IT!!!!!
As long as the contacts are not interfering with eachother it should be ok
You could just repair the bits you need to…
Someone posted recently,for that connector and some are still around if needed
Obviously something made that happen in the first place
You can still get the connectors from vw. I had a similar issue with mine. Reckon it was water dripping onto the fusebox from a damaged scuttle. Perhaps the same happened to yours. Should be ok as long as the pins are not touching. Best to repair it sooner rather than later though.
