break lights switch
(In Topic #85555)
break lights switch
cheers Rob
Web Team
DANSKE n/a 464550010 BRAKE LIGHT SWITCH (3 PIN) T1/T2/LT/GO/PO/PA/A80/A100
3 Pin ?3.94
FAE 464550020 BRAKE LIGHT SWITCH(2-PIN) FITS T1/T2/LT/GO/PO/PA/A80/A100
2 Pin ?4.68
Hope this helps.
ew said
One thing tho, why would you want to go to the hassle and expense of installing a new system when it would be so much easier to just replace the defective part for a couple of quid??
Because it saves having to completely refill the braking system, since the hydraulic switch, if replaced, would introduce air at the master cylinder into the hydraulic circuit.
