Brake Lights???
(In Topic #91344)
Brake Lights???
Can anyone help me out my brake lights have stoped working. I have tried new bulbs but no joy any help would be much appreciated.
Fuse, it's 10 amp, or try the brake switch. Mine went on my Cabby a while ago. Not sure where yours is but mine was by the brake pedal.
Tian :wink:
Tian :wink:
If all fails, check that the retangular electrical block is pushed right up on each rear light, sometimes the spade connectors in the block corrode, so it might be worth taking off the electrical block and checking the connectors.
Thanks for the tips bit scary driving without brake lights had to put her away in the garage till i sort it.
Yeah, the last thing you want is a lorry up your chuff.
Tian :mrgreen:
Brake light switch wires can corrode .
The switch (mine has 2) is under the master cylinder
It is inline to the metal brake pipes
My wire colours are red/yellow and red/black
The corrosion is usually blue coloured
clean off contacts and connections
