Brake Lights Please help urgently...
(In Topic #97601)
All ok. side lights work. It is a 1983 GTI. Ive read other threads and it appears to be operated by a switch on the master cylinder. I ve cleaned the connections and no change. There is one connection on each side of the master cylinder, does anyone know which one is for the brake light switch? If I change the switch do I need to bleed the system? Any help or thoughts would be appreciated as MOT in under 24 hours and I have run out of ideas.
83 Mars red GTI
01 V6 4Motion (daily driver)
09 Golf GTI MK6, candy white, superchipped!
Whatever you do, DO NOT snap off a bleed nipple. I would strongly recomend soaking then in WD40 and leaving over night before you attempt to undo them.
Hope it goes ok.
Jay
Gary.
83 Mars red GTI
