Brake lights on all the time.
(In Topic #85722)
What is the best cure for brake lights staying on all the time on a 1983 Golf Mk1.
Was driving this morning with mine on.
ops:
Well first thing i'd look at is the brake light switch under your brake pedal cos it might have got stuck in the on position. If it's that it's only a few ?'s to replace and an easy job
Anyone else got any other suggestions? Any common faults or anything?
'82 Golf C 1.1
Thought so.
Does anyone have a part number for this, or could tell me if it is a two or three pin switch.
Thanks.
Thanks.
Brake light switch is a hydraulic switch on the master cylinder, I think its just Sciroccos that have a switch on the pedal (it might be a small block thing, all the big blocks have it on the MC???). Some cars have 1 switch, some have 2. If you have 2, then a quick fix would be to disconnect the one which is faulty. The proper fix would mean opening up the hydraulic circuit, so you'd have to bleed the brakes.
Thanks paul-c, looks like I will have to get the system bled and get the job done properly.
Update: 14th March.
Realised that a new brake switch was fitted to this car two years ago. Had a good look at it this afternoon and noticed the wire connector was not seated correctly. Cleaned it all up and brake lights now working perfectly.
Update: 14th March.
