battery / alternator problem
(In Topic #84413)
Is there anything else which could be flattening my battery?
Is there a way of testing the alternator to see if the new one is working properly? I've read some posts about using a multimeter on the wires coming out the alternator and checking voltage is above 13V but I'm not sure how to do this as the wires coming out the multiplug all look sealed up to me.
Any other advice gratefully received. Thanks
simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
I'll try taking the dash apart later on and see if i can see why the lights arent working. Searching the forum it looks as though the multiplug and/or a bad earth may be to blame. Does this sound about right?
Is there a fuse controlling this part of the dash? rev counter, fuel/temp guage and lights in the centre like indicators. The power is definately getting there as the clock is still running which im guessing rules out a blown fuse.
Finally is it likely that the battery continuously going flat is related to the dash problems or am i barking up the wrong tree?
Testing voltage across the battery terminals i got 12.2-12.4v at both idle and while revving engine by pulling choke out. So it doesnt look like its charging.
I opened the back of the plastic plug on the alternator to expose the back of the spade connectors. With the negative multimeter lead on an earth strap on gearbox side of engine and the positive lead on either of the bottom two larger connectors with red leads i got 12.2v while revving engine, same as at battery.
Presumably at least one of these is connected to the battery to carry the charge so, assuming the alternator is working, the voltage should go up when revving like you said in your last post, even if theres a problem elsewhere. However i'm not too good with electrics so could be barking up the wrong tree.
Does this mean the alternators a dudd or should i look elsewhere for the source of the problem?
Im still not sure if the battery light on the dash is working as the dash problem still isnt sorted, see other post. However im guessing that the top connector in the plastic alternator plug is the one goign to the dash mulitplug position 12 (labelled ladek) as they're both blue wires and look pretty similar. There's continuity (tested using ohms setting on multim) between this blue connector in mulitplug and the multiplug earth cable (brown one, no.2) so im assuming the bulbs ok as otherwise it wouldnt read at all.
Is your blue signal wire getting power when the key is on? And you're sure you have a good ground, i think. Then if you have two red wires on your alt. jump them both the the positive on the battery. If you have one then run just that one to the positive (you ahve a single wire alt in that case)
If it's a wiring/harness/fuselink/etc problem, it'll charge. If it's an alt/rectifier/brushes problem, you'll have the same issues after jumping. Just had the same on my 1.7 Wabbit L, turned out one of my red wires was broken somewhere in the harness. made a new one jumping both to the battery until i can make it pretty when it's warmer out. Been working great for a week.
Also, seems to be a lot of this going around. Hrmm. Posted this shortcut on 1203812390 forums today.
I used 8 or 10 guage wire, don't remember which. Working perfectly for me!
I was all set with new wire in hand when my non-driving housemate who i'd roped in to helping me revved the hell out of the engine when i asked her to give it a tap and the alternator suddenly started charging and it now reads approx 13.5v when the engines running.
I'm certain it wasnt working before as i'd been driving around normally flattening batteries for a week and a half. Perhaps the gentle persuation my housemate gave it loosened the new alternator up? I dont know what's happened, but fingers crossed it stays this way.
Cheers for your help guys. I'll post up all the readings i get off each of the red and blue connectors when the alternators charging and not in case its of use to anyone in future. It'll have to be tomorrow though as its now too dark for me to read the multimeter and my housemate has long since got fed up of sitting in the car turning keys and revving the engine when i say so.
Hope that it stays working for you!
If i switch stereo, heater and heated rear window etc on it drops to 11.7/11.8v. Is it safe to assume the 'new' cheapo ebay alternator isnt working properly? The voltage does increase if i tap the accelerator and the lights get brighter but they never used to before all this trouble started.
All the spade connectors, battery connectors and earth straps were meticulously scrubbed and rubbed down with a little wet and dry so should be fine.
You may have a regulator/rectifier problem. Perhaps it's not holding back at higher rpms. If that was the case though your voltage should soar through the roof when you're at the higher speeds. I had an S-10 once that had that problem, always putting out a constant high 20's almost 30 volts. Had to switch the alty as the regulator was internal.
Since doing that the voltage jumped up to around 13.3v with all my stereo, heater, heated rear window etc switched on. The car has run fine without the wire on and ive never seen my windscreen wipers move so fast!
Best of all it didnt cost me a penny, other than the bottle of wine i bought him for helping me out. So if anyone in coventry needs starter motors or alternators head to SAC at Spon End.
