Anyone well good with electrics ??!
(In Topic #90763)
im stuck with the ignition
:dontknow:
please help me :cry:
its fairly simple.
The starter motor will be connected to the battery +ve and chassis grnd.
There will be a feed going from the ign switch to the solenoid on the starter motor, probably via a fuse. (this will stage 3 on the ign switch)
Thats takes care of spinning up your motor.
Next is fuel and spark. Stage 2 will be connected to the +ve on the coil, probably via a fuse and relay.
fuel pump, I cant remember if thats stage 1 or 2, but again wire from the ign switch to the fuel pump relay via a fuse.
Hope the gives you some insight.
Amit
i dont know where the solenoid is or … what it is as a matter lol
There will be two terminals on it.. one is ground, the other is positive.
The ground will be connected to the chassis some how.
Basically the starter motor will have a thick power wire straight from the battery for the main juice, and also another terminal that goes to the ign switch.
Amit
