any suggestions peeps
(In Topic #88992)
i have plugged in the horn and it sounded so i unplugged it lol!??
i took steering wheel off and pluged her back in all good. i touched copper/brass tag to the metal plate and it sounded all good. but when i put the steering wheel back on and start to tighten up the bolt the metal ring on the back off the steering wheel make slight contact with the metal plate about 1/3rd off the way round.
any one any idea how to sort this out as i'm stumped
hello!
Find a differnt steering wheel and fit it? Are the springs in there, which prevent the horn contacts contacting, until its pressed?
If all else fails, Blu-tac. No, seriously. It sorted out the connection issue I was having with my door speaker. Electrical tape could not make it connect, but Blu-tac has kept it in place whilst not being undo-able.
Mind you, I still have a broken toilet after I snapped a polystyrene ball so maybe don't listen to me…
Good luck with it!
Good luck with it!
<img src="http://i35.photobucket.com/albums/d186/Missmoopants/Golfskissing2.jpg" border="0" alt="Two lovely Golfs">
its doing it with the boss for my little steering wheel and the standard one i'll work it out unsure if it was anything to do with the fact i've had everything there off the car and apart to change the ignition barrel and auto pedals to manual one
hello!
I had this trouble with mine. There should be a plastic bush on the top of the column before the wheel goes on. It was missing on mine. From memory it's about 2cm or so tall. It stops the base of the wheel grounding on the metal strip on the column. I'd check if yours is there.
Cheers,
Mark
Cheers,
Mark
its not!! bugger
any one got one
the car booked in for a mot on sat argh!!!!
any one got one
hello!
all sorted now found the spacer in one off my boxes off bits n bobs
hello!
