Alternator
(In Topic #84985)
Alternator
more problems as if i didnt expect them lol.
Anyway just a quickie, the 82 gl has the original motorola alternator, the later ones are bosch.
Question is i noticed the wires going to the original alternator are 2 red and one blue but are connect via plug to alternator, yet the bosch ones have the same wires but no plug just spade connections, would it be ok if i got a bosch alternator and ring'd spades then connect both the reds together and the blue on the other bolt of the bosch.
The alternator i have at moment is 45amp, am i ok by fitting a 65amp :dontknow:
Pete
VW fitted Motorola and Bosch alternators at the same time, not sure what determined which one was fitted to what car and whether they are interchangable, as all combinations seem available on VW parts list.
1983 1100 C
1983 1100 C
You can up amps to an infinity on crappy wires if nothing is using it. Now say you threw a huge alternator on there then hooked a stereo amp up to it through the regular VW wiring, well, the alt could handle it, the amplifier could pull the amps, the wiring would melt.
So basically you're not upping the voltage, because it's still a 12/14volt alternator. Amps don't really matter if you're not hooking up any more demanding electronics that will need to "pull" more power.
Helps when jumpstarting others though.
Pete :wink:
Peddersgolf - looking at the VW parts list, there are various bosch and motorola alternators of between 45 and 65 amp listed. They all seem available for all engines so I have no idea what was fitted to what and why? Maybe it was dependent on the country of sale i.e driving in Northern Europe requires more lights, wipers, heater, cold starts etc than say South Africa or the US.
My Gti had a Bosch 45 amp one fitted, but the guy at GSF said they also sold identical Bosch 55 amp alternators and perversely they were cheaper so I got one. Mk1 and mk2 alternators differ due to the pulley size, but assume this can be swapped.
1983 1100 C
1983 1100 C
No more red battery constantly staying on :mrgreen:
Thank you for your advice guys, it is always appreciated :wink:
