Alternator?
(In Topic #134314)
Alternator?
Could it be just the wiring, or more likely the alternator itself?
Anybody know where I can get a new connector or loom from?
I don't have a lot of time to spend getting these problems sorted and I'm desperate to get it running again.
first of all sort the leak out, is it windscreen or the drain holes in the scuttle, they fill with leaves and muck?
You need to put a multimeter acroos the Bat terminals to see the voltage, with the car off and again with it running should go over 13V, no doubt that if that's wrong one of the Guys will correct me.
Just ask in the parts wanted forum for what you need.
mk3 golf battery cabling is a good upgrade, take the rear engine -> gearbox mounting bolt with the stud on where the battery earth runs to. just you'll need to make up a chunky earth from the -ve to the mk1 chassis leg, you'll see what I mean.
you can go 1 step further and fit the alternator setup off an early 1.8-2.0 mk3 golf, you want the type with the massive spring under the alternator. take the alt, bracket, spring, fixings inc the ones on the block plus the crank and waterpump pullies.
