again on the coolant level sender and the red led flashing!
(In Topic #94075)
![bengi3 in the usergroup ‘Regular’ bengi3 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
The coolant level is ok, the temperature is okay, so what?
I removed the coolant level sender and I realised that it is a pretty weird thing: there are two strange cylinders similar to pHmeters.
Unfortunately nor the Haynes neither the Bentley spend a single word on it, is there any way to test this unit?
Ben
Golf Cabrio 1.8 GTI Quartett, 1989, Helios Blue.
Land Rover Defender MY 2007, Carintia Blue
FIAT 600, 1954, grey
FIAT Panda 4x4 Climbing, 2009, Bianco Bianco
http://homepage.mac.com/bengi/PhotoAlbum36.html
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/snorkler.jpg)
![Tian in the usergroup ‘Local hero’ Tian in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Failing this try another sender.
Tian :wink:
Tian said
The mix of water and coolant is probably wrong. Those little prong things are testing the resistance. If the mix is out then the resistance will be out too causing the warning light to flash.
Tian :wink:
The mix was okay (G12 at the -25?C indications). I have just replaced the sender and the problem is fixed!
BTW. how strong should the sender be screwed? It is plastic with a sort of o-ring. Will the dilatation of the o-ring be enough to keep the system under pressure or a good torque is needed?
Ben
Well done and good luck with it.
Tian :wink:
