16V temperature gauge sits full up with the red light flashing occasionally
(In Topic #158611)
If it is a sensor which one would it be and where is it located?
My New Year's resolutions are: 1. Stop making lists. B. Be more consistent. 7. Learn to count.
rubjonny said
look for the red/yellow wire, it should run to 1 of the 3 sensors in the side of the head. they should all be the same rating, black collar type
Thanks john
Had a similar problem with flashing red Temp light. Eventually traced to faulty level sensor in Expansion Tank - this after trying 2 yes2!! new sensors, both of which proved faulty in differeht ways. Latest offering from GFS was the cheapest and fixed the problem.
